Secware Posted January 30, 2018 Posted January 30, 2018 Recommendations for a keypad and fob activated alarm system with 1/2 motion sensors and 2 door switches compatible with the master blaster 127db alarm siren Quote
stuart_mcg Posted February 3, 2018 Posted February 3, 2018 Hi, any panel should drive the 240v master blaster with 12v relay. Because this is mains driven, you should also add a sab based siren for power failure. The galaxy G2 with a c079 RF portal and TCC fobs will do it for a reasonable price. There's also the galaxy flex with the RF portal that will do the same. Other panels will offer the same. Quote
