November 6, 20178 yr Hi, I recently fitted a scantronic panel and key pad for my parents after there old alarm system went faulty, I could do with some help programming the Scantronic: 1) Door chimes I am unsure weather this has to be activate in the engineers menu and how ? 2) Part Set for night time, I am also unsure how to disable the landing PIR and make it so they have time to access the key pad down on the hall way that is covered by another PIR. Any help would be greatly appreciated. Thanks
