Hi all, wondering if anyone can help please:
I have a wired home alarm system using the Honeywell G2-12 panel. This was an existing wired system and I replaced an old domestic failed panel with a G2-12 panel and MK7 keypad with Keyprox. I now have a programmed up and working inruder alarm system that can be set and unset with users and PIN entry on keypad.
I need to have a Prox Tag programmed in so that the system can be unset from Night Set to keep it simple for the wife to unset the alarm without her glasses first thing in the morning as she is normally first to come down - she is long sighted so only needs glasses for reading which she forgets to bring upstairs and leaves them in the living room and struggles to see the keypad keys and display clearly!
I have programmed a Prox Tag and can set and unset the alarm with the tag (or PIN and tag in any combination of set and unset) only in FULL SET so I know Tags programmed in ok. I normally Night Set the alarm using a PIN and "B" on the keypad however, the only way I can unset the alarm from Night Set is by PIN entry? I cannot seem to be able to unset the alarm with the Prox Tag?
I am coming to the conclusion this maybe a function not possible with G2-12 panel? Can anyone help please? I would think I have gone through the installation manual and programming quite carefully and haven't spotted anywhere, where I might be going wrong. Honeywell expect me to go on their installation course and become a professional installer so they are no help.
Thank You
