Re: Quote required for the above property
Please below what we require for our building, I look forward to hearing from you with a quote as soon as possible;
Supple and Install a "BPT" four button audio door entry system with four headsets to control visitor access.
Two handsets to be installed on the ground floor, and two on the second floor.  The entrance panel is to be a aluminium surface with four call buttons.
The door to be secured would be an electric release in a brass surface mount housing to work with a Yale latch.
We have an electrician who can lay a 4-pair cable from the position of each handset to the entrance panel.
I look forward to hearing from you, if you leave your name and number I will call you back
Kind Regards
Dean Martin Facilities Management
Tel: 01604 250240
