March 14, 20179 yr Hi, Will a Robot vacuum cleaner trigger the alarm? I'm thinking about buying a robot vacuum cleaner but I'm worried that the vacuum cleaner will set off the alarm system. What can I do to avoid false alarms. Is it best to buy pet tolerant movement detectors with dual technology or is it enough with PIR? Or will the alarm go off no matter what kind of movement detectors I use? Best regards Tomas
March 14, 20179 yr It's difficult. In theory it should be ok and I have one myself without a false alarm yet. The only way to be sure is to only arm perimeter protection and disarm the movement sensors
March 15, 20179 yr Author That sounds promising that you haven't had any false alarms yet. But what kind of movement sensors do you have in your home, PIR or dual technology and are they "Pet tolerant"?
