Hello
I have installed system now, only one Magnet contat for Door entry.(Elmdene EN3-LSC)
I've done programming.
Disable all but door contact.
When arming system: Door 'n Hall fails. System don't arm, only beeping( Program 1 set). Walk test gives 0 to Door
What's wrong: is my door contact wrong kind, maybe false wiring or missprogramming ?
Please help !
Respect !
Great thanks
As you have a high security Grade 3 contact there it needs to be a little closer. As a temp measure for testing, remove the magney and temp affix next to the contact (ie right next to it) and it should clear.
James
CHEERS !
Now it seems to work !
MANY THANKS !
This is the next componet, that I will connect to Accenta: GSM link.
Now I must use my own brain.
I love lifetime learning curve  :)
Respect !
