Zorro6 Posted November 17, 2009 Posted November 17, 2009 Is it necessary to solder in-line resistors to all the zone inputs i.e. E/E, PIR and door contacts? With my old Scantronic 9200 I just connected the contacts straight across the inputs on the PCB. The scematic shows a resistor on the e/e input. Thanks Quote
Secware_Tech6 Posted November 19, 2009 Posted November 19, 2009 No its not. You dont solder them, I think your getting confused with high secirty EOL wiring over double pole Quote
