Secware Posted August 30, 2016 Posted August 30, 2016 Hi,Just bought from you a visonic powermaster 30 kit with some additional modules and sensores and have the following questions :1) The Next PG2 K9 motion sensor come with 2 lens, what is the lens that is Pet tolerant?2) I would like to buy a RS232 module to connect to the powermaster using the "Remote Programmer PC Software". Two questions :2.a) What is the RS232 module that it's compatible with the powermaster 30?2.Do you supply also the "Remote Programmer PC Software" ? 1 Quote
Secware Posted September 2, 2016 Author Posted September 2, 2016 Please find the following comments from the manufacturer;1) The Next PG2 K9 motion sensor come with 2 lens, what is the lens that is Pet tolerant?The Lens with the shading will be the pet lens.2) I would like to buy a RS232 module to connect to the powermaster using the "Remote Programmer PC Software". Two questions :You need the USB Programming Kit the RS232 module is the older version.2.a) What is the RS232 module that it's compatible with the powermaster 30?Again you need the USB Programing kit.2. Do you supply also the "Remote Programmer PC Software" ?'You need to register as an installer onĀ Visonics website, then you can download the SW Quote
