Secware Posted October 22, 2015 Posted October 22, 2015 I am planning to import a comprehensive Visonic Power G2 System with many detectorsinto Germany. I understand that all components of the system have to be UK components in order to be compatible.Before ordering I need answers to the followings questions:Can the language of the Power Master 30 panel be changed from English to German?Will the Power Master 30 panel with the GSM-350 PG2 and the Powerlink 3 modules be able to communicate with Visonic’s PowerManage IP/GPRS-based Security Management Platform installed at a German central monitoring station? Will the alarm data and other data transmitted by the Power Master 30 panel to the CMS also be in German?Would I have access and full control of my Power G2 System through the Visonic2Go-App with Powerlink 3?Could I alternatively access and control my Power G2 System via an internetbrowser with Powerlink 3?Would there be an additional charge for the usage of the Visonic2Go-App, which as I understand runs on a Visonic Server.Does the powercord of the Power Master 30 panel have an UK 3 pronged plug or a 2 pronged plug?Which battery backup pack is installed in the panel of the Power Master 30 kit?Does the panel of the Power Master 30 kit have a built in siren? Quote
