rogerdean Posted August 19, 2015 Posted August 19, 2015 Hello, I have a scantronic 500r.+ system installed in 2002 which has been regularly serviced and works as installed. I now have a low battery light for one of the PIRs but the installer & servicer seems to have gone out of business as his phone contact is no longer recognised. Please could you say how to change the battery on the PIR as I do not know whether it has a tamper proof feature or not, hence, if I interfere with the PIR will it set off the alarm? Thanks for your help, Roger Quote
Secware_Tech6 Posted August 19, 2015 Posted August 19, 2015 It will have a tamper alarm. Advise you get an new maintainer to support it for you Quote
rogerdean Posted August 19, 2015 Author Posted August 19, 2015 Thanks for your help. Do you have a list of service companies in the Canterbury area (Kent) Thanks, Roger Quote
Secware_Tech6 Posted August 24, 2015 Posted August 24, 2015 If no one says hello then have a look on the nsi website for an approved firm Quote
