b_bears Posted October 6, 2009 Posted October 6, 2009 Anybody know if the SD2 dialer will work in North America. concerned about the ringer detection circuit as here in North America we use 90V at 20 Hz. Thanks Quote
Secware Posted October 12, 2009 Posted October 12, 2009 Hi, I have spoken to Coopers about your query and I'm waiting for their Technical department to call me back after they have checked this out for you, sorry for the delay, but I will respond as soon as I now the correct answer Regards Elaine Quote
Secware Posted October 12, 2009 Posted October 12, 2009 Hi, Is it possible for you to email me your address, I have had a response from Coopers with how to make the dailler work and I think it would be eaiser for you to have it emailed over incase there is any PDF's, for you to look at, hope this is of help to you Regards Elaine Quote
b_bears Posted October 18, 2009 Author Posted October 18, 2009 Elaine Sent an email to you with my address. thanks for getting the info!! Quote
Secware Posted October 21, 2009 Posted October 21, 2009 Hi Here is a copy of the info you needed, hope this is of help While the SD2 is not tested or approved for use outside of Europe I believe the unit will operate satisfactorily in North America. The unit uses screw terminals for all external connections. The major differences between the networks would be: The ring voltage of 90V - this should be sufficient for detection. Also this is only an issue if you intend to use the remote access features. I suspect the majority of users only use the unit in dial out mode. Network impedance - 600 Ohm network may cause DTMF signalling to fall out of regulatory limits but the unit will still operate. Call progress tones - American ring tone cadence at 2 seconds on / 5 seconds off is longer than UK and much of Europe and may result in the unit replaying its message before the call is answered or to hang-up the call without replaying any message. SMS text messaging - this feature is unlikely to operate in North America due to limited message format / protocol options provided in the unit. Quote
b_bears Posted November 1, 2009 Author Posted November 1, 2009 Just an update in case anybody else here in North America is thinking of getting one of these units. Finally received the device from newark.ca. Works out of the box in the North america pstn other than making up your own RJ-11 phone cord. Then hooked it up to an Linksys pAP2t and adjusted the settings to match those of the UK phone system. I am accesiing the unit through the internet via a DID and it does work fine both for incoming and outgoing connections. The only thing that does not work is the SMS notification. I was aware of this when I bought the unit. Only complaint that I have is on the 2 way audio feature the volume is low to the unit from the PSTN to the SD2. The units speaker just does not have enough gain. If anybody knows the output impedance of the speaker circuit please advise as I would like to connect an external speaker via an amplifier to increase the volume. Seems I have not found anything in the menu system to increase the volume. The microphone in the SD2 has plenty of gain. Quote
Secware Posted November 16, 2009 Posted November 16, 2009 Hi, I have checked out your query about the volume and Coopers say there is nothing you can do to make it louder, sorry can't be of more help this time Regards Elaine Quote
