sparky Posted October 1, 2009 Posted October 1, 2009 can any body advise i need a sensor to cover a gateway to either make or break a contact when somthing or some one breaks the beam the problem is its a 30m gap and i can only get a cable to one side so it has to be reflective or single beam i can get plenty that do 10 meters but cant find any the do 30meters and fed from one side only does any one have any idea makes model cheers nick Quote
Secware_Tech6 Posted October 1, 2009 Posted October 1, 2009 I dont know of a reflective unit that can do more than 11m Can you get power of any sort at the other side, or could you use a passive based system? James Quote
sparky Posted October 1, 2009 Author Posted October 1, 2009 its one of them jobs im afraid there is no chance of getting a cable to the other side a pir system might work if i can find a sensor wich will not pick up a large dog or false alarm on badgers or foxes like in the past do you have any thing in mind Quote
Secware_Tech6 Posted October 1, 2009 Posted October 1, 2009 NOt with 30m range no. Things that spring to mind are pet tolerant risco external detector or a heavily masked opal / voltek pir. Mounting height would be critical though. Quote
sparky Posted October 2, 2009 Author Posted October 2, 2009 do opal do a pet tolerant pir or would i have to mask it Quote
