Secware_Tech6 Posted August 9, 2009 Share Posted August 9, 2009 Please can you supply replacement battery for Omnicron 9000 Series house alarm Thanks Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted August 9, 2009 Author Share Posted August 9, 2009 Leonard the battery is sized for the system and charger. It would probably be best to replace with the same size as is currently installed. James Support Quote Link to comment Share on other sites More sharing options...
