Secware_Tech6 Posted August 9, 2009 Posted August 9, 2009 Please can you supply replacement battery for Omnicron 9000 Series house alarm Thanks Quote
Secware_Tech6 Posted August 9, 2009 Author Posted August 9, 2009 Leonard the battery is sized for the system and charger. It would probably be best to replace with the same size as is currently installed. James Support Quote
