byte Posted August 5, 2009 Posted August 5, 2009 Hi, I have experience with ZM so I'll use that as my recording/detecting, question I'd like to know which is the best mid range day/night vision IP camera which I'm hoping will be wireless have do you sell most of ? I'd like to be able to control up/down/left/right so I'm guessing it will be a PTZ (haven't much camera experince as I've only used an AXIS 206 IP wired camera) Or what would be your ideal way of setting this up i.e I have computer with ZM installed now need a hopefully discrete camera. I know I've been pretty vague but hopefully will get there. Thanks for any pointers. Quote
Secware_Tech6 Posted August 7, 2009 Posted August 7, 2009 Byte I know a bit about ZM but cant help out with that too much. However camera wise i would really recommend any axis camera. IMO there is nothing close to the re image quality. However id consider your requirement for PTZ. As a rule i would only recommend them for manned systems, ie how are you going to ensure your camera is in the correct position when an event occurs? I would recommend wider static views, using megapixel cameras. ZM can do this already. (will need the shared mem to be tweaked) But discrete and good image quailty dont usually go together. Hopefully tahts enough info to start with. James Quote
