September 19, 201412 yr Hi I ahve just purcahsed a Eurosec CP8L panel and a Pyronix Databell Plus Bell box, and would like you to confirm connections as this configuration is not listed in the manauls CP8L Bell+ Bell- Bell HO Strobe + Strove - SAB Tamper In the bell T T STB BELL 12v+ 12v- In addition is it possible to configure PGM1 to give 0v in Engineer mode to disable the bell box tamper. Various settings sre listed but not this one. Any advice apprecaited
September 26, 201411 yr Hi I ahve just purcahsed a Eurosec CP8L panel and a Pyronix Databell Plus Bell box, and would like you to confirm connections as this configuration is not listed in the manauls CP8L Bell+ Bell- Bell HO Strobe + Strove - SAB Tamper In the bell T T STB BELL 12v+ 12v- In addition is it possible to configure PGM1 to give 0v in Engineer mode to disable the bell box tamper. Various settings sre listed but not this one. Any advice apprecaitedBell+...............12v+ Bell-............BELL Bell HO............12v- Strobe +............12v+ Strove - ...........STB SAB Tamper........T The cp8 is a very basic panel and does not iirc have an output suitable
