Spc530.320
accounts3
I recently purchased from you a Siemens SPC530.320 alarm panel and Invincibell Plus amongst other compnents
My question relates to connecting wiring the Invincibell to the SPC530 panel.
In the Invincibell wiring diagram it shows the Bell terminal of the alarm box connected to the bell terminal of teh alarm panel. However on a Siemens SPC530 there is no terminal marked bell so I would like to confirm where the bell terminal of the invincibell should connect to on the Siemens SPC530
SPC
Com-------
NO---------
BHO------
TR------
EX------
EX+------
I also plan to have two Invincibell's connected in the citcuit (front/rear)
An example if you have one would be very much apprecaited
Regards
Gary
you will use one of the programmable outputs programmed as bell for your bell connection. There should be a wiring diagram in the manual for your bells. But personally id of gone for a cqr bell as they are easy to wire up in 2 way.
  • 1 month later...
