Secware Posted May 15, 2014 Share Posted May 15, 2014 We recently purchased a system which includes 2 x Pyronix Deltabell and a honeywell ADE GEN4 metal system. When reading the Pyronix data sheet it states that the bell trigger to the Deltabell must not be in paralled ( ie from one output ) two outputs must be used. The problem is I dont think the GEN 4 panel has a second bell output terminal, or have i missed it?As the deltabell is class 3 we have to install a resistor (4k7) from the +ve to the bell trigger ( to give it aprox 2v or above during normal mode ). With one deltabell this works fine.How should I connect the other deltabell? would a solution be to install a 2K resistor in place of the 4K7 and set both bells to SCB mode? Quote Link to comment Share on other sites More sharing options...
admin Posted May 22, 2014 Share Posted May 22, 2014 We recently purchased a system which includes 2 x Pyronix Deltabell and a honeywell ADE GEN4 metal system. When reading the Pyronix data sheet it states that the bell trigger to the Deltabell must not be in paralled ( ie from one output ) two outputs must be used. The problem is I dont think the GEN 4 panel has a second bell output terminal, or have i missed it? As the deltabell is class 3 we have to install a resistor (4k7) from the +ve to the bell trigger ( to give it aprox 2v or above during normal mode ). With one deltabell this works fine. How should I connect the other deltabell? would a solution be to install a 2K resistor in place of the 4K7 and set both bells to SCB mode? No there isnt 2 bell outputs on that panel. I would suggest the use of a double pole relay to trigger each bell then the high security resistors can be used too. Quote Link to comment Share on other sites More sharing options...
