Logic 6 alarm system as ordered, however it appears to be faulty.
I was replacing an existing unit and wired the PIR’s, door switches and Exterior bell box and strobe. The system immediately showed a fault on the anti-tamper side.
I removed the PIRs and tested the system with door contacts and it worked fine. On testing the 13v power contacts they are not showing any power reading although the batter is running the rest of the system.
It would appear that the circuit board is wired incorrectly. I can confirm that the fuses are intact but no power is being shown at the output side
