I bought an Optima Compact Gen4 over two months ago. Since then I have been trying to connect it to a bell box from another manufacturer without success. Honeywell technical support simply say that I MUST buy their Reson8 siren!
The bell box model is Mars 2000, the instructions and circuitry are attached. I have tried numerous combinations of the panel's A/D/B terminals to the bell's H-/H+/SO terminals but the bell is never triggered by the panel. I know that the bell works because I can manually trigger it by changing the voltage on H+ or H-.
Any tips before I give in and buy the Reson8?
Thanks...
13.8+  = D
13.8-  = A
H- = no connection
H+ = B
SO = Strobe -
LB = No Connection
T = T
You may need a relay for this sounder to be compatible for this panel
Basically this sounder is an old style SCB
You may need a pull up resistor.
If that configuration doesnt work then connect a 1K resistor between B on the panel and D
Alternativly you will need a relay to clean switch the voltage req.
Support
