John-N Posted January 3, 2008 Posted January 3, 2008 Dear sirs, I have an intruder alarm as above. It has two wired remote keypads. Is the Accenta rkp still available or is there a current alternative that will work with this system? Thank you, Quote
Secware_Tech6 Posted January 5, 2008 Posted January 5, 2008 Dear sirs, I have an intruder alarm as above. It has two wired remote keypads. Is the Accenta rkp still available or is there a current alternative that will work with this system? Thank you, Im afraid the old xm based accenta is long obsolete. The new keypad is not supported. Id advise you contact a local approved installer to see if they can help as they may have old stock, or you may be in need of an upgrade. Quote
