May 29, 200916 yr Afternoon, I have recently installed an optima compact gen3 system in my house and added a remote keypad. The system is working fine and walk tests etc with no problems but whilst it is day made the remote keypad and main control box emit a double beep approx every five minutes (very annoying). I've gone through the operating manual and the engineers manual I have and it seems this would be the system telling me of a line fault for the communications system. However, as you as probably aware, there is no comms system on the compact panel. any idea how I can stop it beeping at me please......? Thanks, Neil Annals.
May 30, 200916 yr without knowing hw its programmed i would suggest you have turned on chime on a circuit. best way is to check that, if its not that, then id suggest removing all cabling and linking everything out, to see if the beep still occurs.
June 1, 200916 yr HAve a look in the user manual about chime, and enableing disabling etc starts at page 8
June 1, 200916 yr Author Hold the phone! Sorted it, i found the line fail active high was flagged in "flag b" options menu. Thanks for the help anyway....
