Secware Posted January 20, 2014 Posted January 20, 2014 I have a powermaster30 and would like to use the special features ,"Look after People at home" as described in the manual.in Devices configuraion of my PIR i have set the "DISARM ACTIVITY - YES, No delay" but does not receive any information if i stop moving.Is there anything else i have to configure in the CP to use this feature? Quote
foggy Posted January 20, 2014 Posted January 20, 2014 Never used it, however it is a control panel configuration: 33:INACTIVE ALRT (disabled by default); did you configured it? Quote
Secware Posted January 20, 2014 Author Posted January 20, 2014 Option 33 on control Panel. "Inactivity Alert" Amend to appropriate setting An alert will be sent Quote
tek Posted January 20, 2014 Posted January 20, 2014 Can you confirm if this setting is enabled by default in the older panels like powermax ? Quote
foggy Posted January 20, 2014 Posted January 20, 2014 From a powermax installation guide I looked, it is disabled by default (pag 18 powermax complete installation manual). Quote
