Jimr Posted May 28, 2009 Posted May 28, 2009 Hi I purchased the above panel recently. The user manual suggests that it can be set up in a way that you only need only press the set button rather than entering the 4 didgit code. I cant see in the engineers manual how to do this. Is this the case and if so how do you set it up. Thanks Jimr Quote
Secware_Tech6 Posted May 29, 2009 Posted May 29, 2009 Flag 2 - OptionsSingle Key Set When this flag is set to ON, it allows the panel to be set by pressing the [sET] button. A code entry is not required. However, a 4-digit code is required to Unset the panel. Pressing the [1] button toggles the flag ON or OFF. Page 23 of the engineer manual Quote
