Secware Posted January 6, 2014 Posted January 6, 2014 Can I connect a telephone dialler to the Optima 8EP396A . The instruction manual says the communicator is not fitted to the Optima Compact. Quote
Secware Posted January 6, 2014 Author Posted January 6, 2014 The informa speech dialer is compatible with 8EP396A panel on the bell -ve trigger terminal. Quote
admin Posted January 7, 2014 Posted January 7, 2014 There are no seperate communicator outputs, these are only on the bigger panels, but yes you can trigger it from the bell output Quote
