Secware Posted November 25, 2013 Posted November 25, 2013 I have G4 panel with LED remote keypad.I want to make door chime facility louder, do I need to connect another sounder to rkp or back to main panel? RKP is near door which terminals do I use on rkp and/or G4 panel, I already have extra sounder near main panel, close to back door also set to chime, wired to speaker terminals in main panel but this responds to alarm condition and mirrors rkp sounder when alarm activated but when front or back door is opened then I'm only getting usual beep-bo from rkp.Am I using the right connections in main panel? Quote
Secware Posted November 26, 2013 Author Posted November 26, 2013 Please check the volume control which is on the main PCB board on the panel , it's a potentiometer on the main PCB board please turn it anti clock wise to increase the volume . Please check if you are using a siren instead of speaker on the speaker terminals , if it's a siren it will not give chime tones . Quote
