voulco Posted May 21, 2009 Posted May 21, 2009 Hello! I'm in the process of building a home alarm that consists of the G2-44 Panel and I'd like to know a couple of things: Provided that I have installed a RF Portal, 1. Will this Glass Break Detector that Securitywarehouse supplies (Model: DOM-BG- work with the Galaxy system? 2. Will the KTC 805 keyfob work with the system? If I'd like to purchase the FlexGuard Glass Break Detector and Magnetic Contact (model FG-1608T) as well as the TCB8M Keyfob would it be possible for Securitywarehouse to order them? Thanks! Looking forward to hearing from you. Quote
Secware_Tech6 Posted May 21, 2009 Posted May 21, 2009 If there is a product that we dont list, if you let us know we will either order in and stock or offer as a special order item only, (ie longer lead time) re will the 2 products work on a galaxy with portal, yes they will. Support Quote
