vorbis Posted May 14, 2009 Posted May 14, 2009 Hi I'm interested in getting the Visonic Powermax+ Quickfit Kit (inc Wireless sounder). What Keypanel do you recommend? I assume it's recomended that you put the control panel in a closet or something and not close to the door? Also, can the whole kit run on battery only? if so, for how long? BR Quote
Secware_Tech6 Posted May 15, 2009 Posted May 15, 2009 it will only run on batteries for about 12 hours, so you do need a std mains supply for the panel. keypanel wise you can either use the arming station only or the 2 way keypad. Quote
