I would like to upgrade our Galaxy 512 with Ethernet module in order to control the system remotely and to when need be, handle programming and updates through Internet interface, rather than using one of the MAP's in the system.
My understanding is that this could be done by complementing our existing system with an additional Honeywell Galaxy Ethernet Module (Model: E080-2) from you, and also I guess, I need to upgrade the SW that currently running as that is an old version, - Ver. 1.27. Our Galaxy 512 motherboard is Rev1.6.
Pls. let me know if my thoughts are right, and if so provide me with the pricing for the ROM/EPROM for the SW upgrade, and if needed any additional upgrade or retrofits that might be needed to in order to get this done.
The E080-2 is the correct module, however it will only work on version 4.0 or above on the Classic range.
As for the prom to upgrade, I have checked with Sales Support and these are no longer available, the panel would need a ram replaced (desoldered) for version 4.00 s/ware also.
