Hi
I have a WR 300 RECEIVER AND A WT 101A SENDER.
tHIS OPERATES A POOL COVER.Motor
i HAVE JUST REPLACED FAULTY RELAY IN THE SYSTEM.
The motor works fine but the receiver whislt flashing when I hit the sender button does not operate.
Tabs down oreceiver 1 and 8 Tabs down on the sender 1 3 and 8 not touched either piece of eqipment since it stopped working.Any ideas would be helpful Thank you.
  • Like 1
You will need to match the switches that are ON/OFF with the receiver and the transmitter, once they're the same on both then the unit should function fine
