Secware Posted April 9, 2013 Posted April 9, 2013 I would like to exspand the system I have,which is PA 4 WIRED alarm (Friedland)to ad to the system with two OPTEX SAVER NEW QUAD PIR. Would this be suitable.The movement detectors I have,have got 6 connections in it. Quote
Secware Posted April 18, 2013 Author Posted April 18, 2013 You should have no problem at all wiring the Saver detector to your system, this system I believe is a double pole panel. Wire the Alarm pair into one of the zones, (Z1,Z2,Z3,Z4) and wire the tamper pair in series with the other devices in to the 24Hr terminal on the panel. See attached manual for reference. www.securitywarehouse.co.uk/brochure/45165PL Ed.2 - PA4.pdf Quote
