Secware Posted February 25, 2013 Posted February 25, 2013 From the manual of MC-302E PG2: "A 47k? E.O.L. resistor must be wired at the far end of the zone loop" Is this value (47000?)of the resistor correct? or it means 4k7 (4700?) resistor? Quote
Secware Posted February 25, 2013 Author Posted February 25, 2013 i want to buy some of these contacts to use them with the MC-302E PG2. From the info of this contact it says that it has 6 terminals. Is there a way to connect these 6 terminals to the 2 input zone of the MC-302E PG2 and use all the benefits ? or this is impossible and i'll just have to buy a 2 terminal contact ? Is there a way a 2 terminal contact to be used with E.O.L wiring or then i have to buy 4 terminal wich i suppose they have tamper terminals to do that Quote
