Purchased Accenta Mini G4 from you and have only just got round to installing it. On first power-up, I noticed that the walk test had a 1 under the P indicating a problem in the PA circuit. When I logged out of Engineer Mode I am also receiving a "PA Fault Lockout". I removed the PA button I had fitted suspecting a wiring problem and returned the factory fitted link on the PA terminals. I am still seeing the above fault and am left with an alarm in an unusable state.
Any ideas of what might be causing the problem?
  • Like 1
PA Fault lockout means that the PA circuit is staying open, as stated that you have linked out the PA circuit and that should have cleared the fault, however if the Engineer reset is enabled you will need to reset the system by typing the engineers code.
So when you see that message on the display simply enter the engineers code and that should clear the fault as you have already linked out the PA circuit.
