May 11, 200917 yr I order and received your Secware Optima 4 x PIR Kit and a Honeywell ADE Informa Speech Dialler. The kit content description on your site is: 1 x Honeywell Optima Gen4 Mini Control Panel (8EP396A) 4 x Crow Swan 18m Value PIR's 1 x Ventcroft Evolution SAB and Cover (Blue Strobe) 1 x 100m 6 core Intruder Alarm Cable 1 x Secware Value 2.1 A/h Battery 1 x Surface Door Contact I actually received an Optima Gen 4 Compact Control Panel won
May 11, 200917 yr Mike The optima compact is correct and does match the description. Im not sure i understand the question as it will work with a dialler, and the optima even has dedicated outputs even though most people just connect it to the bell output. You do not need an interface. Support
May 11, 200917 yr Author Hi, The Optima Compact don't have the dedicated outputs and if I wire to the bells output I will only get one alarm type where the dialler supports three. Regards Mike
May 11, 200917 yr Oh i see. Yes your quite right the optima compact does not have the additional outputs. This is on the larger panels only. from manual 5 digital outputs for a wire-in digital communicator or dialler(Not applicable for Optima compact panel).
May 11, 200917 yr Author Hi, Can I return the Compact and buy the ADE Accenta Mini Gen4 with LCD Keypad then? Regards Mike
May 11, 200917 yr Mike RMA for this order 1247627 Authorised Reason Would prefer to swap for a panel with outputs. If you send that panel back in original packing complete etc, and the reorder the panel you prefer. Support
