KB Posted May 8, 2009 Share Posted May 8, 2009 I require a wired alarm system supporting a minimum of 8 detectors with the following key characteristics: Ability to set/unset using the lock on the final exit door, eg using a Chubb 3G114 Single Pole Shunt Lock or similar If the alarm is activated the ability to disable the strobe (in addition to the sounder) after a predetermined period of time, so there is no external indication of the alarm having been triggered Can anyone please recommend the a control panel / sounder combination which is able to support this configuration Many Thanks KB Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted May 8, 2009 Share Posted May 8, 2009 any panel with a keyswitch input. BUt for ultimate and full lexability id suggest a galaxy dimension or texecom premier. SUpport Quote Link to comment Share on other sites More sharing options...
KB Posted May 8, 2009 Author Share Posted May 8, 2009 any panel with a keyswitch input. BUt for ultimate and full lexability id suggest a galaxy dimension or texecom premier. SUpport Thanks for that, will the texecom also enable the strobe to be turned off after a predetermined time? Also will the Texecom Veritas Excel (which has keyswitch input) allow the strobe to be turned off after a predetermined time? Regards KB Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted May 8, 2009 Share Posted May 8, 2009 no but if you wire the strobe trigger off the bell trigger they will both stop at the bell time limit Support Quote Link to comment Share on other sites More sharing options...
KB Posted May 9, 2009 Author Share Posted May 9, 2009 no but if you wire the strobe trigger off the bell trigger they will both stop at the bell time limit Support Thanks Quote Link to comment Share on other sites More sharing options...
