May 5, 200917 yr Dear Sir or Madam, I have sent two emails via your website but there were problems with this last time I used it as your spam filter had a problem with my email address. I've also sent a fax (last week) but no response..!! I purchased 1 Risco Gardtec G-Tag keypad last year on order 7119 and I ordered 2 more recently on order 11893 (see below). The first one was a 6 wire keypad and the next two are 4 wire. According to the installation details you can
May 5, 200917 yr Roy You are right you cant mix them. We always update our equipment on the site as soon as the new versions are released. I will get returns to contact you so we can swap those parts for you. Support
May 8, 200917 yr Author Dear Support, Thanks for the response. When & how do I get my RMA so I can return the two keypads? Regards, RoyP
May 8, 200917 yr Author Many thanks.. I'll get the two keypads in the post ASAP. I assume once you recieve them back you will ship the correct (6 wire) ones to the original delivery address? Regards, RoyP
May 19, 200916 yr Author Dear Support, You should have the two 4 wire keypads by now. Could you advise when the 6 wire ones will be sent out please? Or do you add these as an order on my account so I can track it? Many thanks. RoyP
May 22, 200916 yr Author Dear Support, I really need to know when the 6 wire key pads are going to be sent out. Grateful for a response..... RoyP
May 27, 200916 yr Author Dear Support, I need to know when the new keypads are going to be sent out. This is becoming a problem now... RoyP
May 28, 200916 yr Roy Sorry for the delay in getting back to you, as i assumed this was being dealt with by returns. I have now looked into this and will try to get them sent out today. If not it will be tomorrow now, but i will let you know as soon as they are despatched. Im sorry about this Roy, i shoudl of kept an eye on your return as it was non standard James
May 28, 200916 yr Author James, Many thanks. I'd be very grateful if you could let me know when they go out. Best regards, Roy.
