June 7, 201115 yr Hi, Our alarm has been giving us problems for about 2 weeks. It indicates an intermittent problem with the PA and low battery - the alarm goes off intermittently as well. we have changed the battery in the main control panel and the PA. We have inherited this system and have done nothing with it apart from keeping the PA to hand (and changing the batteries), it has never been armed. What advice can you give? We would be happy to disconnect the thing and switch it off completely - but when I try (by removing the fuse) the outside alarm goes off. Please help - it is driving us nuts especially during the night when it goes off for no reason. One thing - this problem has only started since a new person has moved into the house. Would appreciate any advice - we have the manual but I can't find anything that tells us how to shut the whole thing down. Thanks
June 9, 201115 yr Sorry we can not give information on a public forum as to how to disable an alarm, you could get quotes from your local alarm companies.
