June 3, 201115 yr I am looking for 18 shock sensors to replace some existing ones. What is the difference between the Aritech GS611 and the GS710 (apart from the 611 has an additional reed switch) ?
June 16, 201115 yr AS far as I know, that is the only difference. You need to wire these detectors through an enertia analyser such as the GS614 or GS 615.
