May 23, 201114 yr Hello.  I'm trying to wire an external Sounder to my Powermax+ Central but I don't know how to wire it. So please help me 😞  The sounder is a Cranford Spatial Sounder Datasheet  Thanks in advanced!
May 24, 201114 yr Author Hello again.  I have received a reply from Cranford about this and as they have said I wanted to double check with you if this is right or not.  Would be very grateful for quicker reply.  Here is the answer: Good Afternoon, Many thanks for your enquiry and we apologise for the delay in getting back to you but please find below some information that maybe of help.  The VTG12V should be wired so that the +ve terminal is fed to either pin 5 or 6 on the VTG, and the negative or ground connected to pin 3 or 4 on the VTG12V. I believe that the positive 12V can be taken from a 12V pin on the right of diagram 3.3 in the PowerMaxPlus manual sent to us. And therefore I
