Secware Posted May 20, 2011 Posted May 20, 2011 I'm interested in the said PIR (Texecom Prestige Compact IR), but i would like to know if it supports the EOL wiring. Quote
Jaguar Posted May 20, 2011 Posted May 20, 2011 Provided you install resistors of the required value - YES. Quote
sups Posted May 20, 2011 Posted May 20, 2011 J, I originally asked this question to SW, and they posted it up here. I have had a look on line and there is conflicting info about this PIR some supplier/individuals saying that the resistors are built in and it simply a matter of adjusting a jumper setting, others like yourself say that the PIR would need the resistors installing manually. I'm confused Quote
