Secware Posted May 18, 2011 Posted May 18, 2011 last April it has worked perfectly. However recently, although it texts me on arming and disarming, if I try to control the system remotely ie arm, disarm, status it fails to respond. This was a relatively expensive piece of equipment and although just over one year old, I would have expected it to have lasted longer than this. It is operating with a Premier 24 panel (although only partially now!) Quote
Jaguar Posted May 20, 2011 Posted May 20, 2011 Is the phone line wired into the digi modem? Is there broadband on the line? Have you fitted an ADSL filter? Have you changed your mobile phone provider? You could try cycling the GSM unit. If this fails check the panel programming is correct. Quote
