Posted
Hi all, im just wondering if the, Texecom Prestige External TD Outdoor Motion Sensor, is compatable with the texecom veritas r8 system, if so how is it connected and can you use the chime facility?
thanks daniel
Posted
The TD motion sensor would be compatible with any control panel, so yes also with the R8. It can be wired in ID, double pole or end of line, and if the zone is programmed for chime, then this facility would work
Regards
Sec ware Team
