dannywilko Posted May 12, 2011 Share Posted May 12, 2011 Hi all, im just wondering if the, Texecom Prestige External TD Outdoor Motion Sensor, is compatable with the texecom veritas r8 system, if so how is it connected and can you use the chime facility? thanks daniel Quote Link to comment Share on other sites More sharing options...
accounts3 Posted May 13, 2011 Share Posted May 13, 2011 The TD motion sensor would be compatible with any control panel, so yes also with the R8. It can be wired in ID, double pole or end of line, and if the zone is programmed for chime, then this facility would work Regards Sec ware Team Quote Link to comment Share on other sites More sharing options...
dannywilko Posted May 13, 2011 Author Share Posted May 13, 2011 thats good, thankyou, do i need 1 or 2 devices - 1 at each end? im looking to install it to the side of my garden. Quote Link to comment Share on other sites More sharing options...
accounts3 Posted May 13, 2011 Share Posted May 13, 2011 These motion sensors are not beams, so do not come as pairs, as to needing one or two, this would depend on the area to be covered. Quote Link to comment Share on other sites More sharing options...
dannywilko Posted May 13, 2011 Author Share Posted May 13, 2011 ok, i see now, if i was to want beam detectors do you stock any which would be compatable with the texecom veritas r8 Quote Link to comment Share on other sites More sharing options...
accounts3 Posted May 16, 2011 Share Posted May 16, 2011 All manufacturers beams would be compatible, it depands on the range you require as to which beam you choose Quote Link to comment Share on other sites More sharing options...
