anwarawan Posted March 31, 2009 Posted March 31, 2009 I have an optima gene4(8EP396A) I want to install a remote keypad can I use a optima lcd (8EP417A) with this panel or do I have to use an led keypad.Please can you instruct what is best to use with this panel. Quote
Secware_Tech6 Posted March 31, 2009 Posted March 31, 2009 the Gen 4 optima and accenta will accept lcd, led or easy set readers. you can also mix them on the same system. The 3G optima and accenta will only accept an led keypad. Support Quote
