SJ200 Posted March 10, 2009 Posted March 10, 2009 I have replaced an old Optima XM6 panel with a new Optima Compact panel The system works fine with program 1 My problem is I cannot get it to part set using program 2 I enter my code, the exit beep starts, but when I press the PROG key, the exit tone, that should stop, keeps going, so I can't get to select program 2 Tried reset to factory defaults but it did not help Thanks Quote
Secware_Tech6 Posted March 11, 2009 Posted March 11, 2009 you need to enable the other part sets. Have a look in the manual and there are setting types for each part set. You will notice part set 2 is defaulted to 'none' ie disabled. Support Quote
SJ200 Posted March 12, 2009 Author Posted March 12, 2009 That fixed it. Thank you very much for your help. Quote
