securitywarehouse Posted February 14, 2011 Posted February 14, 2011 texecom prestige ir would that work with texecom excel.does it depend on eol of the control panel and the pir to work together. Quote
stuart_mcg Posted February 14, 2011 Posted February 14, 2011 I do not believe the Prestige IR sensors have the EOL resistors incorporated within the sensor. It's a lower cost sensor, so wouldn't expect it to. There's nothing to stop you using EOL or non-EOL sensors with the panel though. You can: 1. Set the panel for normally closed operation and do not fit the resistors. 2. Fit one 10k resistor at the sensor and set the panel to "American" operation. 3. Fit one 33k resistor at the sensor and set the panel to "European" operation. 4. Fit one 10k and one 22k resistor at the sensor and set the panel to "High Security" operation. **My preference** Just check the installation manual. Simples! Stu. Quote
