February 10, 200917 yr Hi My 13 year old Omnicron 7000 panel has finally given up the ghost. I am looking for advice on a replacement which will require minimal changes to the wiring. Any suggestions very welcome. Paul
February 10, 200917 yr id suggest you have a look at the accenta poly. You could use an optima compact but there is very little room inside the case. Support
February 14, 200917 yr Author Thanks for that info, I just need a main panel remote key pads are not required.
