asdgroup Posted January 23, 2009 Posted January 23, 2009 just a quick question might sound daft but need to know never the less. does the secware sound bomb wire into the extension speaker terminals?? ive never worked with these before. ASDGROUP Quote
Secware_Tech6 Posted January 25, 2009 Posted January 25, 2009 ASD a soundbomb is a switched 12v unit so no. The extention speaker outputs are for just that a speaker. You would normally wire the soundbomb between bell trigger and a perm 12v + Support Quote
asdgroup Posted January 25, 2009 Author Posted January 25, 2009 i thought as much had to check tho. thanks. Quote
