INTRUDER ALARM {WIRELESS SYSTEM}
surinder
Hi, i need help deciding between a PowerMax + (Visonic) or the Scantronic 9751-EN-00 55K for a 5 bedroom house. I need a 5 PIR, 8-10 shock sensors and 1 door contact with a wired outside bell, with a dial out facility. I also want to be able to hardwire the system to the garage later on. If not is there a better system that you could recommend? Any help would be greatly appreciated
Many thanks,
Surinder J
Thanks again for your help, and yes i did mean the full wired bellbox. I would like it to have a flashing LED light when it's active, not just when the alarm is going off. If I cant hard wire the bellbox to homelink 75 then could you kindly give me full list of all the parts i'll need for the homelink 55 to make a full kit which will contain an internal sounder, outside wired bellbox with flashing LED, dial out facility for 4 numbers with wireless 5 pir, 8 shock sensors, 4 key fobs and 1 door contact, and anything else you think I may need. I really do appreciate your time and help.
Thanks.
