surinder Posted January 14, 2009 Posted January 14, 2009 Hi, i need help deciding between a PowerMax + (Visonic) or the Scantronic 9751-EN-00 55K for a 5 bedroom house. I need a 5 PIR, 8-10 shock sensors and 1 door contact with a wired outside bell, with a dial out facility. I also want to be able to hardwire the system to the garage later on. If not is there a better system that you could recommend? Any help would be greatly appreciated Many thanks, Surinder J Quote
Secware_Tech6 Posted January 20, 2009 Posted January 20, 2009 The powermax is a fine system but on a personal note if i could get a wire there then i would. The powermax will be an easier install and program. Hybrid panel the scantronic homelink or the galaxy 2-20 kit would be the ones to look at. Support Quote
surinder Posted January 23, 2009 Author Posted January 23, 2009 thanks for your help. can you please tell me is homelink 75 is hybrid system. do i need anything else to connect wired led bellbox, if yes can you please tell me catalouge no to order. thanks again kind regards Quote
Secware_Tech6 Posted January 25, 2009 Posted January 25, 2009 Surinder The homelink 55 is hybrid but the 75 is wireless only. When you say 'wired led bellbox' do you mean a full wired bellbox or just an led? Support Quote
surinder Posted January 26, 2009 Author Posted January 26, 2009 Thanks again for your help, and yes i did mean the full wired bellbox. I would like it to have a flashing LED light when it's active, not just when the alarm is going off. If I cant hard wire the bellbox to homelink 75 then could you kindly give me full list of all the parts i'll need for the homelink 55 to make a full kit which will contain an internal sounder, outside wired bellbox with flashing LED, dial out facility for 4 numbers with wireless 5 pir, 8 shock sensors, 4 key fobs and 1 door contact, and anything else you think I may need. I really do appreciate your time and help. Thanks. Quote
Secware_Tech6 Posted January 26, 2009 Posted January 26, 2009 Homelink 55 http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=1345 External Sounder Ventcroft Classic http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=678 Internal SPeaker http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=662 Speech Dialler http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=1348 Scantronic Wireless PIR http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=520 Scantronic Wireless Vibration Sensor http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=523 Scantronic Door Contact http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=693 You may need cable, fused spur, Battery for panel (Yuasa 7A/h) Decoy Sounder Support Quote
surinder Posted January 27, 2009 Author Posted January 27, 2009 Thanks for all the help. It's all clear for me now! Thanks again. Quote
